Test procesorów AMD Ryzen 9 9900X vs Intel Core i7-14700K - Porównanie w grach i programach. Komu potrzebne dwa moduły?
- 1 - Test AMD Ryzen 9 9900X - Wstęp
- 2 - Test AMD Ryzen 9 9900X - Taktowania fabryczne
- 3 - Test AMD Ryzen 9 9900X - Temperatury
- 4 - Test AMD Ryzen 9 9900X - Metodyka pomiarowa (FAQ)
- 5 - Test AMD Ryzen 9 9900X - Platforma sprzętowa
- 6 - Test AMD Ryzen 9 9900X - 7-Zip
- 7 - Test AMD Ryzen 9 9900X - Autodesk Maya
- 8 - Test AMD Ryzen 9 9900X - Blackmagic
- 9 - Test AMD Ryzen 9 9900X - Blender
- 10 - Test AMD Ryzen 9 9900X - Cinebench (ST)
- 11 - Test AMD Ryzen 9 9900X - Cinebench (MT)
- 12 - Test AMD Ryzen 9 9900X - Corona
- 13 - Test AMD Ryzen 9 9900X - DigiCortex
- 14 - Test AMD Ryzen 9 9900X - Dolphin
- 15 - Test AMD Ryzen 9 9900X - HandBrake
- 16 - Test AMD Ryzen 9 9900X - JavaScript
- 17 - Test AMD Ryzen 9 9900X - Shotcut
- 18 - Test AMD Ryzen 9 9900X - Stockfish
- 19 - Test AMD Ryzen 9 9900X - Veracrypt
- 20 - Test AMD Ryzen 9 9900X - Visual Studio
- 21 - Test AMD Ryzen 9 9900X - Assetto Corsa Competizione (1920x1080)
- 22 - Test AMD Ryzen 9 9900X - Assetto Corsa Competizione (2560x1440)
- 23 - Test AMD Ryzen 9 9900X - Assetto Corsa Competizione (3840x2160)
- 24 - Test AMD Ryzen 9 9900X - Baldur's Gate III (1920x1080)
- 25 - Test AMD Ryzen 9 9900X - Baldur's Gate III (2560x1440)
- 26 - Test AMD Ryzen 9 9900X - Baldur's Gate III (3840x2160)
- 27 - Test AMD Ryzen 9 9900X - Cyberpunk 2077 (1920x1080)
- 28 - Test AMD Ryzen 9 9900X - Cyberpunk 2077 (2560x1440)
- 29 - Test AMD Ryzen 9 9900X - Cyberpunk 2077 (3840x2160)
- 30 - Test AMD Ryzen 9 9900X - Dying Light 2 (1920x1080)
- 31 - Test AMD Ryzen 9 9900X - Dying Light 2 (2560x1440)
- 32 - Test AMD Ryzen 9 9900X - Dying Light 2 (3840x2160)
- 33 - Test AMD Ryzen 9 9900X - Hogwarts Legacy (1920x1080)
- 34 - Test AMD Ryzen 9 9900X - Hogwarts Legacy (2560x1440)
- 35 - Test AMD Ryzen 9 9900X - Hogwarts Legacy (3840x2160)
- 36 - Test AMD Ryzen 9 9900X - Microsoft Flight Simulator (1920x1080)
- 37 - Test AMD Ryzen 9 9900X - Microsoft Flight Simulator (2560x1440)
- 38 - Test AMD Ryzen 9 9900X - Microsoft Flight Simulator (3840x2160)
- 39 - Test AMD Ryzen 9 9900X - Spider-Man Remastered (1920x1080)
- 40 - Test AMD Ryzen 9 9900X - Spider-Man Remastered (2560x1440)
- 41 - Test AMD Ryzen 9 9900X - Spider-Man Remastered (3840x2160)
- 42 - Test AMD Ryzen 9 9900X - Starfield (1920x1080)
- 43 - Test AMD Ryzen 9 9900X - Starfield (2560x1440)
- 44 - Test AMD Ryzen 9 9900X - Starfield (3840x2160)
- 45 - Test AMD Ryzen 9 9900X - Total War: Warhammer III (1920x1080)
- 46 - Test AMD Ryzen 9 9900X - Total War: Warhammer III (2560x1440)
- 47 - Test AMD Ryzen 9 9900X - Total War: Warhammer III (3840x2160)
- 48 - Test AMD Ryzen 9 9900X - Witcher 3: Wild Hunt (1920x1080)
- 49 - Test AMD Ryzen 9 9900X - Witcher 3: Wild Hunt (2560x1440)
- 50 - Test AMD Ryzen 9 9900X - Witcher 3: Wild Hunt (3840x2160)
- 51 - Test AMD Ryzen 9 9900X - Pobór mocy (Spoczynek)
- 52 - Test AMD Ryzen 9 9900X - Pobór mocy (Render)
- 53 - Test AMD Ryzen 9 9900X - Pobór mocy (Gra)
- 54 - Test AMD Ryzen 9 9900X - Overclocking
- 55 - Test AMD Ryzen 9 9900X - Sumaryczna wydajność (Gry)
- 56 - Test AMD Ryzen 9 9900X - Pamięć RAM Lexar ARES RGB
- 57 - Test AMD Ryzen 9 9900X - DDR5 6400 MHz vs 7000 MHz (Sync vs Async)
- 58 - Test AMD Ryzen 9 9900X - Podsumowanie
Microsoft Flight Simulator to nieliczny przedstawiciel gatunku symulatorów lotniczych, wykorzystujący autorski silnik dewelopera, który niemal całkowicie polega na wydajności pojedynczego rdzenia. Microsoft Flight Simulator pozwala wybierać między DirectX 11 oraz DirectX 12, jednak nowsze API okazuje się bardziej problematyczne od starszego (kwestia stabilności). Testy zostały przeprowadzone w Nowym Jorku, podczas wznoszenia helikopterem na określoną wysokość. Wąskie gardło ze strony procesora jest wówczas ogromne.
Microsoft Flight Simulator - New York
1920x1080 / Ultra / LOD 400 / AI ON / DATA OFF / DirectX 11
3400-4500 MHz, DDR4-3600 MHz CL14
3800-5500 MHz, DDR5-7000 MHz CL32
3900-5400 MHz, DDR5-7000 MHz CL32
4400-5600 MHz, DDR5-7000 MHz CL32
2500-4600 MHz, DDR5-7000 MHz CL32
2500-4400 MHz, DDR5-7000 MHz CL32
3300-4300 MHz, DDR5-7000 MHz CL32
4700-5300 MHz, DDR5-7000 MHz CL32
3700-4800 MHz, DDR4-3600 MHz CL14
2500-4400 MHz, DDR4-3600 MHz CL14
3300-4300 MHz, DDR4-3600 MHz CL14
3400-4600 MHz, DDR4-3600 MHz CL14
3500-4400 MHz, DDR4-3600 MHz CL14
3800-4600 MHz, DDR4-3600 MHz CL14
3900-4500 MHz, DDR4-3600 MHz CL14
3600-4200 MHz, DDR4-3600 MHz CL14
- 33
- 34
- 35
- 36
- 37
- 38
- 39
- 40
