Test karty graficznej PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB - Jeden z tańszych modeli, a okazuje się całkiem udany
- 1 - Test PNY GeForce RTX 4080 XLR8 - Wstęp
- 2 - Test PNY GeForce RTX 4080 XLR8 - Budowa i specyfikacja
- 3 - Test PNY GeForce RTX 4080 XLR8 - Platforma pomiarowa
- 4 - Test PNY GeForce RTX 4080 XLR8 - Miejsca pomiarowe
- 5 - Test PNY GeForce RTX 4080 XLR8 - 3DMark Time Spy
- 6 - Test PNY GeForce RTX 4080 XLR8 - Assassin's Creed: Valhalla
- 7 - Test PNY GeForce RTX 4080 XLR8 - Call of Duty: Modern Warfare II
- 8 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077
- 9 - Test PNY GeForce RTX 4080 XLR8 - Dying Light 2
- 10 - Test PNY GeForce RTX 4080 XLR8 - Forza Horizon 5
- 11 - Test PNY GeForce RTX 4080 XLR8 - God of War
- 12 - Test PNY GeForce RTX 4080 XLR8 - Hogwarts Legacy
- 13 - Test PNY GeForce RTX 4080 XLR8 - Red Dead Redemption 2
- 14 - Test PNY GeForce RTX 4080 XLR8 - Spider Man: Miles Morales
- 15 - Test PNY GeForce RTX 4080 XLR8 - The Callisto Protocol
- 16 - Test PNY GeForce RTX 4080 XLR8 - Witcher 3: Wild Hunt Next Gen
- 17 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT)
- 18 - Test PNY GeForce RTX 4080 XLR8 - Dying Light 2 (RT)
- 19 - Test PNY GeForce RTX 4080 XLR8 - Metro Exodus (RT)
- 20 - Test PNY GeForce RTX 4080 XLR8 - Spider Man: Miles Morales (RT)
- 21 - Test PNY GeForce RTX 4080 XLR8 - Witcher 3: Wild Hunt Next Gen (RT)
- 22 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT / DLSS 2 / XeSS / FSR)
- 23 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT / DLSS 3)
- 24 - Test PNY GeForce RTX 4080 XLR8 - Overclocking
- 25 - Test PNY GeForce RTX 4080 XLR8 - 3DMark Time Spy (OC)
- 26 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (OC)
- 27 - Test PNY GeForce RTX 4080 XLR8 - Blender
- 28 - Test PNY GeForce RTX 4080 XLR8 - DaVinci Resolve
- 29 - Test PNY GeForce RTX 4080 XLR8 - Pobór mocy
- 30 - Test PNY GeForce RTX 4080 XLR8 - Pomiar temperatur
- 31 - Test PNY GeForce RTX 4080 XLR8 - Pomiar głośności
- 32 - Test PNY GeForce RTX 4080 XLR8 - Sumaryczna wydajność
- 33 - Test PNY GeForce RTX 4080 XLR8 - Sumaryczna wydajność (RT)
- 34 - Test PNY GeForce RTX 4080 XLR8 - Podsumowanie
Temperatura otoczenia podczas testów wynosiła 22 stopnie Celsjusza (+/- 1). Karty umieszczone były w obudowie, która otrzymała trzy 120 mm wentylatory. Taka konfiguracja zapewnia środowisko pomiarów zbliżone do warunków w jakich sprzęt pracuje w typowych komputerach. Na wykresach najkrótszy słupek oznacza temperaturę w spoczynku (pulpit), środkowy to temperatura pod obciążeniem na ustawieniach fabrycznych, natomiast najdłuższy słupek to temperatura pod obciążeniem po podkręceniu. Jako program do wygrzewania posłużył Wiedźmin 3: Dziki Gon, który świetnie wysyca limity energetyczne układów graficznych.
![PurePC](https://www.purepc.pl/files/Image/do_artykulow/water/150_A100.png)
Temperatura rdzenia
2400 MHz (Base) 2970 MHz (Boost)
16 GB GDDR6X 256-bit 25000 MHz
2210 MHz (Base) 2600 MHz (Boost)
20 GB GDDR6 320-bit 22000 MHz
2500 MHz (Base) 3015 MHz (Boost)
12 GB GDDR6X 192-bit 23400 MHz
2380 MHz (Base) 2650 MHz (Boost)
24 GB GDDR6 384-bit 22000 MHz
1805 MHz (Base) 2575 MHz (Boost)
8 GB GDDR6 128-bit 15200 MHz
2530 MHz (Base) 2955 MHz (Boost)
8 GB GDDR6 128-bit 20800 MHz
2145 MHz (Base) 2955 MHz (Boost)
12 GB GDDR6X 192-bit 23200 MHz
2350 MHz (Base) 2775 MHz (Boost)
8 GB GDDR6 128-bit 18800 MHz
1520 MHz (Base) 1980 MHz (Boost)
12 GB GDDR6 192-bit 17200 MHz
2485 MHz (Base) 2985 MHz (Boost)
24 GB GDDR6X 384-bit 23600 MHz
2055 MHz (Base) 2845 MHz (Boost)
8 GB GDDR6 128-bit 19800 MHz
2405 MHz (Base) 2925 MHz (Boost)
1935 MHz (Base) 2425 MHz (Boost)
16 GB GDDR6 256-bit 17200 MHz
1610 MHz (Base) 1920 MHz (Boost)
8 GB GDDR6 256-bit 16000 MHz
1535 MHz (Base) 1935 MHz (Boost)
1685MHz (Base) 2100 MHz (Boost)
24 GB GDDR6X 384-bit 22500 MHz
1610 MHz (Base) 1950 MHz (Boost)
8 GB GDDR6 256-bit 15800 MHz
1850 MHz (Base) 2600 MHz (Boost)
8 GB GDDR6 128-bit 19200 MHz
1465 MHz (Base) 1875 MHz (Boost)
12 GB GDDR6X 384-bit 21000 MHz
1675 MHz (Base) 2040 MHz (Boost)
8 GB GDDR6 256-bit 15300 MHz
2005 MHz (Base) 2325 MHz (Boost)
1500 MHz (Base) 1950 MHz (Boost)
10 GB GDDR6X 320-bit 20000 MHz
1990 MHz (Base) 2375 MHz (Boost)
16 GB GDDR6 256-bit 17000 MHz
2430 MHz (Base) 2650 MHz (Boost)
1500 MHz (Base) 1980 MHz (Boost)
11 GB GDDR6 352-bit 15300 MHz
2070 MHz (Base) 2600 MHz (Boost)
2130 MHz (Base) 2550 MHz (Boost)
16 GB GDDR6 256-bit 17500 MHz
- 27
- 28
- 29
- 30
- 31
- 32
- 33
- 34
![Test NVIDIA GeForce RTX 4080 Desktop vs NVIDIA GeForce RTX 4090 Laptop GPU - Sprawdzamy faktyczne różnice w wydajności](/files/Image/m165/43772.png)
53![Test Ghost of Tsushima PC - Porównanie NVIDIA DLSS, AMD FSR i Intel XeSS oraz omówienie technik antyaliasingu](/files/Image/m165/43674.png)
52![Test wydajności kart graficznych Ghost of Tsushima PC - Dobra optymalizacja i piękna grafika. Samuraj nie dokonał seppuku](/files/Image/m165/43673.png)
83![Test Senua's Saga: Hellblade II - Porównanie wersji PC oraz Xbox Series X. Analiza technik NVIDIA DLSS, AMD FSR i INTEL XeSS](/files/Image/m165/43658.png)
45![Test wydajności Senua's Saga: Hellblade II - Unreal Engine 5 zapewnia piękną grafikę! Jakiej karty graficznej potrzeba?](/files/Image/m165/43639.png)
